i have a 98 dyna wide glide the right rear turn signal does not flash the front right turn signal stays lit but does not flash.either. i read that if the rear bulb is bad the front signal will not flash also... any truth to this. i would appreciate any help.
Pop the right rear bulb out and switch with the left rear... if problem follows the bulb.. you probably have a bad bulb.. if problem doesn't follow the bulb, you have a bigger problem... wiring .. or ?
