Rebuild kit for TC heads?
Old 07-20-2018 | 03:47 AM
Kingglide549's Avatar
Kingglide549
Well you have a whole lot of problems going on there and calling me an idiot is not helping you
LOL
You dont set your pushrods in increments for one!
But this will beat the hell out of your cam and wheels on the lifters..
So your master mechanic BS is pretty much that, along with a parts guy solving all your problems for you.
The running header states" rebuild kit for TC head", Now what part did I miss?
There is no GD thing nowhere period.
Your springs will not cause any clicking ticking problems, but will allow valve float and bent valves it not correct and on the other side of 6K RPM.
I douby=t it is your problem
You being a master mechanic and all dealing with the elementary here is a bit confusing to me.
Afj pushrods do not come lose unless they were not ever locked with the jam nut.
Like I said you have to know what your thread count is to center your lifters correctly, or the clicking will drive you nuts
Old 07-20-2018 | 06:01 AM
Nickd2689's Avatar
Nickd2689
LOL
how is it elementary for me to ask if anyone sells a rebuild kit? If I’m replacing valves, springs, keepers, etc, i would call it rebuilding the head. I don’t know what your problem is but all you’re really doing is talkin **** and picking apart every post I write. You’re just a guy on the Internet to me dude I could really give a hits ht you think about me or my mechanical skills. I know what I do for a living and I don’t care if you believe it or not. I have never researched different valvetrain components so I am completely uneducated as to what is available and what products are worth buying. I asked for suggestions for replacement parts and asked if anyone offered everything I needed sold as a kit hence the term rebuild kit. You can get mad and run your mouth all you want but if I have a question about something I haven’t dealt with before, I’m gonna ****in ask. You’re not gonna make me feel stupid cause you disagree with a word I use. When someone says “rebuild kit” most people automatically know they’re looking for each serviceable part included in one package. It doesn’t matter if it’s a engine or a brake caliper, it’s a ****in rebuild kit plain and simple. You don’t have to include your whiny little insults with your “help”. And I’ve known 3 people so far who claim to have had one of their adj pushrods come loose on them at some point so maybe you don’t know everything after all.
Old 07-20-2018 | 08:35 AM
archergodwin's Avatar
archergodwin
Originally Posted by Nickd2689
ok let me clarify, I started by adjusting the pushrods according to the instructions, heard excessive noise while running so other members told me they’ve had to adjust their pushrods further so I slowly adjusted until the noise I was hearing was gone. I ended up adjusting them an additional 6 flats before the noise stopped. Others told me to go further but I’m not comfortable pushing it that far. So when I say I’m as far as I can go, I mean they’re adjusted as far as I’m comfortable with. That was my first experience with adjustable pushrods but I’ll never trust them not to come loose so at some point he’ll be coming back out.
Gotcha... just wanted to check. I pulled my adjustables out for the same reason... being adjustable and therefore 'loosen-able', just kept nagging in the back of mind... couldn't get rid of it... so I put 1 piece back in.
Old 07-20-2018 | 08:52 AM
Nickd2689's Avatar
Nickd2689
yea I just don’t trust em. I locktited the **** out of mine and the only reason I got em was cause my se rods wouldn’t work with the s&s lifters cause of the travel limiters. I had a problem with the travel limiters so I just removed them completely. Of the three guys I know who had them come loose, one was my father in law (he knows his ****), another was another friend of mine who’s also a tech at the same dealer with me, the last one is just one of the club guys I know but the point is that two of em know engines so I know they didn’t f up the install.
Hoboandy
06-15-2018 09:08 PM
98hotrodfatboy
EVO
20
07-27-2016 05:01 PM
Blowby
09-10-2014 03:45 PM
evolution12c
EVO
11
05-06-2008 05:39 AM
pino56
05-14-2006 09:53 PM
Quick Reply: Rebuild kit for TC heads?
