Dyna starter
Initially I suspected the battery and it was replaced, bike manufacture in 2011 and mileage only 12000km. I suspect the starter and starter ring gear. I have order a new aftermarket starter with higher wattage to replace the original starter. I realized that other Dyna of the same model also facing the same problem. Will update after I replaced the starter.
If you are experiencing a situation where the starter engages but then seems to let go after a couple of cranks and a failed firing, and you hear what sounds like armageddon in the primary, better to look at your compensator.
A worn comp will cause what seems at first to be starter issues, when in fact its a worn compensator not "compensating" as it should.
I'd be surprised if the ring gear was done in. Mines a 2010 with just over 90K km, Original ring gear and starter are still perfectly fine.
Received 4,808 Likes
GREENOHAWK69 (07-17-2018)
This. Have had both replaced and typically it's the starter clutch assembly that needs to be replaced (place that fixes starters can replace if you pull the starter). Just replaced my starter with a brand new one thanks to a lifetime warranty. 97 WG.
GREENOHAWK69 (09-07-2018)
