Main Frame Chassis
Old 07-07-2018 | 10:10 PM
That Girl's Avatar
That Girl
2nd Gear
Default Main Frame Chassis
What main frame chassis are interchangeable with a 2013 Fat Bob FXDF?
Old 07-07-2018 | 10:14 PM
misfitJason's Avatar
misfitJason
2006 and up. All of them
Old 07-07-2018 | 10:23 PM
Reindeer's Avatar
Reindeer
Wide Glide is different rake. But I think all the others are the same.
Old 07-07-2018 | 10:33 PM
That Girl's Avatar
That Girl
2nd Gear
So 2006 and up FXDF frames are the same? Are there any other Dyna that have the same frame. So would the front clip and rear swingarm from Fat Bob fit on a 2011 FXDC or does it have to be FXDF or can it be 2013 street bob frameQUOTE=misfitJason;17494474]2006 and up. All of them[/QUOTE]
Old 07-07-2018 | 10:41 PM
That Girl's Avatar
That Girl
2nd Gear
So all 2006 and up Dynas have the same chassis? So I can put Fat Bob parts on a street bob chassis and vice versa or super glide parts on a Fat Bob chassis? I don’t want to have Fat Bob parts and not be able to put them on a chassis if they aren’t going to be compatible. If a frame is considered a Fat Bob is it because of the chassis or because of the parts as far as swing arm, steering, etc.
Old 07-07-2018 | 10:44 PM
That Girl's Avatar
That Girl
2nd Gear
All 2006 Fat bobs? What about other Dynas, like an 07 Dyna FXD?
Old 07-07-2018 | 11:02 PM
JohnMn's Avatar
JohnMn
Basically they're all the same except for the WG and it's 34° rack,(vs 29° of the others), but there are subtle differences in the location of anchor/bolt locations for exhaust, brake lines, wire harnesses and other things like that.
Some have counsel mount gauges, other have riser mounted,, so sure,, things can swap over,, but,,
What are you thinking of doing or hoping to do??
Old 07-08-2018 | 09:34 AM
That Girl's Avatar
That Girl
2nd Gear
I bought a salvaged 2013 Fat Bob at an auction with a warped frame so I’m wanting to rebuild something using the existing parts so I need to order a new frame that it will all bolt up to.
Old 07-08-2018 | 09:53 AM
Reindeer's Avatar
Reindeer
So it appears there is some difference in frames other than just the Wide Glide. I punched a couple different years and models into Ronnie's HD parts finder index, and it shows a few different part numbers for different years/models. I only checked a couple, so I don't know where the cutoff is, and I don't know what the differences are.
Part # 47760-10A is the frame for a '13 Far Bob.
Old 07-08-2018 | 01:29 PM
crusader1xxx's Avatar
crusader1xxx
If you order a frame from Harley, just order the same frame.....for the same bike you just bought....
or or are you looking used? Seems to me the only reason to write the bike off at the yr you have is if the frame is bent so used might not be an option....
Quick Reply: Main Frame Chassis
