Confused in Colorado
If the axle is not going in you don’t have the wheel aligned properly, I use a jack on my lift table and lower the bike onto the wheel, slowly until the axle slide right in. Make sure you follow the service manual for torque spec. Also grease the axle.
do not bang on it with a hammer.....bumping it with your hand is all the pressure you need....
