Rocker Box Oil Leak
Old 06-27-2018 | 06:16 PM
WS6 Formula's Avatar
WS6 Formula
Default Rocker Box Oil Leak
Lower rocker boxes to heads had a minor oil leak that was burning onto the rear head pipe heat shield. Both were leaking at the forward side of the rocker boxes. I checked the torque before I removed anything and the lower rocker box bolts to the heads were loose (#3's & #4's). Also found oil inside the air filter, most likely the breather valve (see video below) as the rubber valve (#34) was pretty hard after twelve years. Degreased all the bolts and threaded holes, used blue Loctite. I put on another two hundred miles and no more oil leaks. Not a difficult job but it is time consuming.
The following 2 users liked this post by WS6 Formula:
Robottom (06-28-2018), ROCKOUT Rocker Products (06-27-2018)
Old 06-27-2018 | 07:34 PM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Did you drill the oil return holes to an 1/8th inch under the breathers?
Old 06-27-2018 | 09:23 PM
Sponsor
Nice work
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 06-27-2018 | 10:42 PM
archergodwin's Avatar
archergodwin
Did my rocker boxes and breathers, along with a kit to lock the rockers, when I did cams, lifters, bearings...etc... 2 weekends ago.
Old 06-27-2018 | 11:26 PM
Krazy8s's Avatar
Krazy8s
nice work, cool post
Old 06-28-2018 | 02:29 PM
Robottom's Avatar
Robottom
Excellent post, thank you, getting ready to do this and a little more in the next couple of weeks.
Old 07-05-2018 | 12:33 PM
WS6 Formula
twism_23
Touring Parts
05-07-2018 12:02 AM
Jollyczar
Shovelhead
18
04-02-2017 08:55 PM
mclldavidson
Engine Mechanical Topics
10-20-2016 08:29 AM
57RebelRocker
02-11-2011 10:58 AM
mystic97z
12-27-2008 08:48 PM
Quick Reply: Rocker Box Oil Leak
