FLD Accessory Plug
FLD Accessory Plug
Purchased a 2011 FLD recently and first time posting but have been trolling for information for weeks.
I'm trying to find the plug where I can connect 70264-94A for an accessory to no avail. Can anyone point me in the right direction? Pictures below show the battery area and I don't see either the the B+ or Accessory plug, and the only other plug that looked remotely similar is what I believe to be the O2 connector.
Thanks in advance.
Middle plug disconnected
Battery compartment
Thanks in advance.
Battery compartment
Thanks for the part number and that's right, it's a Switchback and had a typo... mine is a 2013 (not 2011 as I originally stated).
72673-11 connector question
I have heated grips and running lights I want to attach to the switched connection terminal.. Can I wire more than one accessory to the one terminal with our overloading the load?
Thanks, Cardo
The connector 72673-11 has 3 pin terminals to connect the accessories to, one is always hot, one is ignition switched hot and the third is a ground.
Thanks, Cardo
Thanks, Cardo
