FLD Accessory Plug
Old 04-01-2020, 10:52 AM
Cardohog's Avatar
Cardohog
Cardohog is offline
3rd Gear
Originally Posted by FXD2003Rider
What's the model & year of your bike?
2014 Switchback..thank you
Old 04-01-2020, 01:10 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Here's a simplified wiring diagram showing the wires that go to the accerey plug, als known as DLC (Data Link Connection).
The entire wiring diagram can be found using this link.
This plug has 6 pins.
Here's what I think you can use:
pin 6 (hot wired directly from the battery) can be used to wire accessories using up to 15 amp
pin 5 (not hot wired) can be used as a command line to activate a relay
pin 2 is ground
According to this Instruction Sheet you have to connect the heated grips' wiring to pin 5, 4 and 2 of the Electrical Connection Harness (H-D Part No. 72673-11)
Here's a wiring diagram on how to wire aux/running lights using a relay.
If you ask me I would connect the passing lamps as shown below, and not using pin 6 to feed the relay...
Signal current from switch (86 ==> 85) activates coil; coil activates internal relay switch (30 ==> 87)
30 = + from battery (requires mim 2,5 mm2 (12 AWG) wire)
87 = + to lamps (requires mim 2,5 mm2 (12 AWG) wire)
85 = ground
86 = + (using a switch to activate relay) from:
- battery (best option for canbus bikes) or
- running lights (blue wire) or
- low beam (yellow wire) or
- high beam (white wire)
Here's a link to some Wire Gauge Tables which will help you to determine the awg wire size needed.
Old 04-01-2020, 01:49 PM
Cardohog's Avatar
Cardohog
Cardohog is offline
3rd Gear
Thank you, this is helpful.. 👍
FXD2003Rider (04-01-2020)
paid4c4
07-09-2015 09:11 PM
paid4c4
Electrical/Lighting/Alarm
07-07-2015 07:01 AM
JonW
2014-2023 Touring Models
06-14-2015 01:32 PM
TriGeezer
04-08-2015 11:44 PM
2kids3pets
11-19-2010 08:11 PM
Quick Reply: FLD Accessory Plug
