Black Denim Street BOB pics
#32
RE: Black Denim Street BOB pics
http://i33.photobucket.com/albums/d8...9/IM001385.jpg
http://i33.photobucket.com/albums/d8...9/IM001386.jpg
#33
Justa5o
180hd tire, custom fender from wcc (tombstone), I mounted it lower to give the appearance of the bike being lower while still maintaing cornering clerance, led taillight bulbs with run, turn, brake converter. I got rid of the circuit board from the stock taillight and shortened up the wiring harness in the rear and ran the wires between the struts and covers so there will be no rubbing issues.
#34
#35
#36
#37
ORIGINAL: rocklayer2
Richwarchild your bike looks incredible!!! Did you buy your suicide shifter premade or did you fab it yourself? Do you have any closups of the shift linkage? I would love to do that with my bob.
The clutch was swapped over to a hydraulic clutch from a V-Rod because i'm still working on a way to have the clutch on the bars work along with the clutch on the jockey for them OHH **** STOP moments.
Here's the closest pic I have to it for a close up.... I've had alot of inquiries about it... Maybe i should patent the bitch :P
This is the original shift linkage I made for it. It was a little to far of a reach for me so I grabbed a stock one from harley that was made fora sportster.
Done a few more changes from this close up. Changed the allen bolt to a custom screw to match the axel (seen in the other pics), Chromed the whole arm, designeda new clutch lever and made it out of solid brass that resembles brass knuckles,and also put a skull top on it which makes a great hand rest.
#39
haha thanks.... I get bored at work and design motorcylce parts for me and my friends. Sissy bar mounts, jockey shifts, forward controls, fender mounts...... The joys of knowing Solidworks(what they use on American Chopper).
That whole piece.... if you wanted to keep the standard clutch, so just mounting plate, shift arm, and clutch handle, linkage.... probably looking at about $300-$400. Of course you could get alot fancier with the mounting plate, shift arm, clutch lever style, etc. And then of course the finish you want on it.
