94 wide glide no start
94 wide glide will not start, no spark to coil. Replaced all circuit breakers, coil, plugs, run stop switch (not the wiring), complete charging system stator etc. Running a crane cams hi-4 ignition (8 yr old). At first it would start and run fine. Then ready for a road trip bike started fine let it warm up. Shut it off and got my leathers on and went out bike wouldn't start. All the replacement components was because of this. Run out of ideas of what could be wrong. Last thing I can think of is replace run/stop and wires (bought a new one) or my electronic ignition is bad. Any help would be greatly appreciated. New battery as well, turns over fine, all other such as lights/turns/horn all work.
If you got a wiring diagram I would suggest going over everything that is wired and check for power and grounds at all connectors. No spark at the plugs and work your way back from there. Check the coil for power into it. Since it’s cranking over it’s got to be in the ignition system, just got to find it. Good luck!
I too have an evo and have found posting in the evo forum you get a lot more help. There are some real guru's over there that know their bikes inside and out. They also seem to be a lot nicer most of the time. You won't have people tell you stupid **** like "you don't belong here". Good luck and hope you get it fixed.
