14" apes on 07' Street Bob
I'm sure I'm beating a dead horse here..
gonna buy burly 14" narrow 1inch apes.
can I use the stock cables/wires on my 2007 street bob?
if not, and I get the extension cables kit, can I run the cables/wires thru the bars? I want braided lines but they're too expensive so I'd rather run it thru the bars..
what else do you guys reccomended for this install?
thanks!
thanks!
I haven't measured them, but I pulled off what I'm pretty sure are 16" apes from my 07 Street Bob that the last owner installed. They're definitely longer than the stock mini apes. They were internally wired. The harness was not cut into or spliced, and there were no cable extenders. The clutch cable, throttle cable, and front brake line were all replaced with longer versions. Something like 2-4". I can measure everything out tomorrow if you want.
cijs88 (05-24-2018)
ill be measuring my cables when i get the chance and compare! thanks
vandykemc
07-31-2008 04:11 PM
