I’m done scraping in soft corners
Old 05-17-2018 | 05:38 AM
Durham man's Avatar
Durham man
Progressive 12.5 , great shocks.
Originally Posted by fxrnutt
Progressive 970's are great shocks with a lifetime warranty. Been riding em fro 3.5 years on the LR. The progressive haters probably have never been on a well set up bike.....
that and they are trying to convince themselves that spending a grand on shocks was a wise purchase. Any shock is going to be better than the garbage burly slammers he is running.
Old 05-29-2018 | 08:36 AM
brownie4412's Avatar
brownie4412
Update-
I did get a pristine set of touring air shocks installed and they are WONDERFUL. Night and day over those slammers. The top acorn nut was cross threaded on to the stud on the left side, so that took a little bit of time to correct (mostly because my Hanson tap and die set doesn't have a 1/2-20). All things considered, this is easily one of the best mods i've done.
fxdlx (06-09-2018)
Old 05-29-2018 | 11:19 AM
Phipps's Avatar
Phipps
I just ordered the 11" Drag Specialties adjustables a previous member showed. Will report back but I think will be a real nice way to get the back down without that 10.5" scrape issues and better damping.
Old 06-07-2018 | 11:40 AM
Phipps's Avatar
Phipps
Installed the 11" Drag Specialties and did the Progressive front drop at 1".
Handles great and definitely shortened the Wide Glide
Old 06-07-2018 | 12:39 PM
gleam's Avatar
gleam
Fully adjustable, piggyback shocks that come in 14" length that are under 1000USD? Awesome.
https://www.getlowered.com/racingbro...7-harley-dyna/
Then I scroll down to the bottom: Fits: 1991-2017 Harley Dyna Models (Except FXDF)
Typical fat shaming oppression. Seriously though, what's different about the Fat Bob rear end that would make these not work? I thought I had a winner here because I'm also done with scraping in corners.
Old 06-07-2018 | 06:51 PM
brownie4412
thats a good question. I know guys take the stock fxdf shocks and put them on street bobs so it stands to reason that any shock that would fit a street bob *should* fit a fat bob. I'd say its worth a phone call.
Old 06-07-2018 | 06:54 PM
Phipps's Avatar
Phipps
I’d almost guarantee they would fit. Frame dimensions are same and I would be shocked if the swingarm is different. Hopefully they just didn’t list your model
Old 06-07-2018 | 07:17 PM
gleam's Avatar
gleam
I don't mean to derail your thread OP, so please let me know if I am, but here's what I've found for anyone reading this:
- Swingarm for 2011 Dynas is P/N 47820-10 (ALL) which means FXDL, FXDWG, FXDC, FXDB, and FXDF
- There are three different part numbers for frames, FXDF has its own with P/N 47760-10 but my guess is that the only difference is the neck
- Shocks P/N 54615-01 is for FXDWG, FXDC, and FXDB
- Shocks P/N 54534-09 is for FXDL
- Shocks P/N 54537-08A is for FXDF
- Bushing P/N 54556-84 (ALL)
I bet they listed it as not fitting FXDF because the stock Fat Bob shocks are a different length, therefore it's not a direct replacement. As mentioned, it probably does actually fit, it's just a different length and that's what they're trying to indicate. Worth a call for sure. Are you meant to get your own Harley bushing for these aftermarket shocks?
Old 06-07-2018 | 09:16 PM
Phipps's Avatar
Phipps
Great info there. That makes me feel even more confident it would work for the OP
IndianSummer
02-14-2019 11:45 AM
Scooby1426
09-01-2018 12:46 PM
Bigdenjw
Carburetor Related
07-24-2018 07:21 AM
fxdx1985
05-11-2018 09:16 PM
BruceT1971
01-15-2018 05:13 PM
Quick Reply: I’m done scraping in soft corners
