Sputhe chassis stabilizers?
Old 05-13-2018 | 05:54 AM
cggorman's Avatar
cggorman
Isn't the whole point of those mounts to prevent lateral movement, eliminating the need for additional stabilizers?
Old 05-14-2018 | 02:23 PM
adamsrotors's Avatar
adamsrotors
Originally Posted by fxrnutt
Whose they? Allen sputhe is dead
really guy? they're still in business. the company of course...customer service.
Originally Posted by misfitJason
The sputhe and true track will not work with the big bear or chopperhaus mounts. 100%
weird...they're assuring me they do. wonder what that's about.
Old 05-14-2018 | 05:29 PM
misfitJason's Avatar
misfitJason
here is a visual representation of why they wont work. The sputhe front mount attaches to the stock rubber mount on the dyna, which is no longer present when you use the chopperhaus mount. On the rear it's the same ballgame. I am not trying to be a dick, I just don't want you to waste your money buying two separate products. They are wrong though and they will not work together. It's either one or the other
Old 05-14-2018 | 07:41 PM
adamsrotors
ah I see. sad Sputhe is so unaware of that.
but I do think the rear would still work. what's the top portion mounting too?
Old 05-14-2018 | 08:29 PM
cggorman's Avatar
cggorman
Sputhe rear mounted to stock isolator...
MMH (04-11-2019)
Old 05-14-2018 | 10:11 PM
adamsrotors
it could technically work with extended bolts but yes you're right...I guess it's one or the other.
I've got to believe these mounts should do a better job, so I guess I'm good...just wanted to do everything I can. I'm fine with overkill here, but I guess it's not an option.
Old 05-14-2018 | 10:23 PM
Dynaglide92's Avatar
Dynaglide92
you have a great setup already if anything it’s the design of the dyna frame that comes up short..if you want more stability get a gpr stabilizer and or an inverted front end lol
Old 05-14-2018 | 10:27 PM
adamsrotors
^ speaking of which...been looking into these. that's on my list along with a swing arm.
Old 05-15-2018 | 12:15 AM
fxrnutt's Avatar
fxrnutt
Why are you asking all these questions if you have all this **** figured out.... You seem to have all the answers "guy"....good luck
Old 05-15-2018 | 12:47 AM
adamsrotors
it was in reference to you telling us he’s dead, a pointless response which was just you letting us know you bought directly from him when he was alive...they clearly being a company in business still, I’ve been in contact with them which was wrong in saying it would work, which I found to be the case from other members.
Quick Reply: Sputhe chassis stabilizers?
