O2 Sensor Issue
2012 Superglide Custom
Powervision tuner
Stock O2 sensor/port
Front O2 Sensor - getting O2 Fault code. engine light stays on.
Changed exhaust from a Thunderheader back TO stock exhaust.
This is the second O2 sensor that has thrown this code in the last 2 riding seasons.
The 1st time it did it, I switched exhausts TO my Thunderheader, got the code, replaced the sensor. Cleared it and everything was fine.
Is it normal for these O2 units to crap out the minute you remove it from the exhaust? I even unplugged it so the wires wouldn't get wound up...
Also is there a special tool to install and remove these? It was a real bitch to get a wrench on it....
one more Q. Is there a cheaper alternative then buying one from the dealer...they are pretty expensive up here in Canada.
Powervision tuner
crusader1xxx (04-27-2018)
The stock o2 sensor is a 12 mm narrow band (the threaded portion). I think a 14 mm open end wrench or o2 sensor socket is needed to remove, but I could be wrong on this front. It’s been a few years since I messed with my exhaust.
Thanks to all who replied. I think you dlporter are correct, its a 14mm.
Went to the local auto parts place and all they had was the 22mm socket, so I bought a cheap 14mm deep socket and I am going to cut a slot ....
who would have thought finding a O2 sensor socket would be so difficult....lots for the 18mm one that takes the 22mm socket...no one carries the smaller sized one....I guess that is why Harley can charge $300+ for the tool
UncleUtOh (05-03-2018)
