HD Detachable Sissy Bar for FXDF or FXDWG measurements
Old 04-24-2018 | 09:54 AM
Velocity Ray's Avatar
Velocity Ray
Default HD Detachable Sissy Bar for FXDF or FXDWG measurements
If anyone has the HD One Piece Detachable Sissy Bar for a late model Wide Glide or Fat Bob, can you please post the measurements between the mounting holes. I'm having Edward Richie at Etsy fabricate a detachable bar for my bike, and I need the exact measurements between the mounting holes of one that fits on the detachable docking hardware. If anyone that has this configuration on the wider platform, either in this setup or with the detachable brackets, I'd greatly appreciate the assist. Thanks.
Old 04-24-2018 | 10:17 AM
JW1200's Avatar
JW1200
I have one I use on my 2009 FXDL. If you think this is what you need, I'll get measurements and take pics for you.
Old 04-24-2018 | 10:27 AM
Velocity Ray
Unfortunately, it's not.. The Wide Glide and Fat Bob have a wider fender, so the detacheables that mount outside the struts have a wider base on these models, in comparison to other Dynas. I appreciate your response though, thank you.
Old 04-24-2018 | 10:35 AM
JW1200's Avatar
JW1200
Your welcome.
Old 04-25-2018 | 10:45 AM
Tomahawk309's Avatar
Tomahawk309
Center to center is 10 3/8" on my 08 FB with the HD detachble sissy bar.
Old 04-25-2018 | 10:49 AM
Velocity Ray
Thank you. Do you know if those measurements vary between the mounting holes? That's what he's asking for, and I'm assuming they do, bc the strut covers are actually wider where the bolts pass through than in the rear.
Old 04-25-2018 | 11:01 PM
Velocity Ray
Can you tell me if the brackets run parallel or if they widen? Also, does anyone know if the fender width changed at all between model years?
Old 04-29-2018 | 11:27 AM
Tomahawk309
No on mine...Parallel...Not sure on the newer style fender.
AUTOT3K
07-26-2019 04:23 PM
WMX124
08-12-2014 02:04 PM
stytches
09-14-2012 02:06 AM
bklanecky
09-11-2009 07:54 AM
skip3406
12-09-2008 09:57 PM
