Metallic thrashing sound
Old 04-22-2018 | 11:33 AM
gzrglyde's Avatar
gzrglyde
Stage I
Default Metallic thrashing sound
1998 HR Road King with 96" S&S Evo motor, 55k miles on motor. Runs strong, but when I let off the gas it makes a god awful metallic thrashing sound, like there are two or more metal surfaces vibrating against each other. If you get on it the sound goes away completely, and this occurs in all gears, mostly noticed when decelerating or if I sit in neutral and rev, it is noticeable.
Old 04-22-2018 | 11:34 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Welcome to the site.
Old 04-22-2018 | 12:02 PM
Ghost_13's Avatar
Ghost_13
Check/ adjust the primary chain tension..., and tensioner
Ghost
Old 04-22-2018 | 12:03 PM
TwiZted Biker's Avatar
TwiZted Biker
Ghost
What he said and Welcome to the hood
Old 04-22-2018 | 08:45 PM
crusader1xxx's Avatar
crusader1xxx
Even though it’s a RK we won’t hold that against you. Lots of very knowledgeable people on the dyna side...
Old 04-22-2018 | 11:12 PM
Krazy8s's Avatar
Krazy8s
Id be checking the compensator sprocket while you're in there looking at the Primary tensioner.
Old 04-23-2018 | 07:23 PM
Ed Ard's Avatar
Ed Ard
I had a similar issue and it wound up being a loose baffle.
Old 04-23-2018 | 07:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Welcome, check your heat shields or just replace the clamps for the heat shields.
Old 04-23-2018 | 10:57 PM
Kcougar's Avatar
Kcougar
I have been battling a similar issue. Almost like a heavy sewing machine noise letting off throttle. Dealer says cant replicate. No information in forum search. Fluids correct and not an outside noise such as a heat shield. Feels enternal. 08' wideglide. Following.
Mitch26
02-13-2015 09:05 AM
fullautomike
08-10-2014 05:48 AM
AllenG
09-23-2013 04:27 PM
hawaiian
EVO
04-26-2011 07:06 AM
Edmo
25
05-14-2007 09:52 PM
Quick Reply: Metallic thrashing sound
