Constantly throwing kickstand springs
Old 04-04-2018 | 09:34 PM
supermanotorious's Avatar
supermanotorious
Default Constantly throwing kickstand springs
I am so pissed about this one. It's been like a nagging not-so-hot significant other that you absolutely need as a smash-piece but constantly throws you under the bus.
The "stud" on the bike for my kickstand spring has consistently let the spring fly off cause of minor bumps for about the past year and a half. I'm not going to go in to details but tonight was the last straw.
I'm about to weld some crazy **** to this Dyna unless someone chimes in with a better solution. Why does this thing suck?
Attached Thumbnails Constantly throwing kickstand springs-img_5202.jpg   Constantly throwing kickstand springs-img_5200.jpg
Old 04-04-2018 | 10:46 PM
supermanotorious
thanks but no thanks, I welded something up which'll never come apart unintentionally and NO I did NOT weld on the spring itself
Old 04-04-2018 | 11:15 PM
riderboy1961's Avatar
riderboy1961
Glad you made a fix for it!
Old 04-04-2018 | 11:32 PM
Ghost_13's Avatar
Ghost_13
After putting on the F-U kick stand - angle was such that it kept throwing springs off the pin (I say springs as it threw 2 off before I got fed up)
Took a spring..., heated one end tip w/ a torch - then bent it up a little - so as it swung around the pin.., it would "dig" in - (deeper into the recess just behind the pin head)..., instead of trying to "dig" itself off (out of the recess and off the pin head)
Never had the issue since
Ghost
Old 04-04-2018 | 11:37 PM
Brsblls's Avatar
Brsblls
If kickstand is bent or twisted it could be the cause of springs coming loose. Had this happen on a 2005 FXD. Got it straight and no more trouble.
Old 04-04-2018 | 11:48 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Crimp the spring end around the pin, then grease the pin. Now the spring slides around the pin.
Had the spring fly across the garage floor when I brought it home from the dealer, back in 1994. (1995 FXD.)
Friend rides his 1996 FXDConvert over. Extends jiffy stand, spring flies across the garage floor. He's a diesel mechanic. We crimp the spring loop around the pin and grease it. Both our bikes' jiffy stands worked "better than designed" until he traded his in on a softie (about 2000) and mine until 2015 when I got my FXDL. I fixed the new bike right off the bat. Sometimes, ya just gotta wonder...
Old 04-06-2018 | 12:14 AM
USMC2010's Avatar
USMC2010
That spring stud should be replaceable. I damaged mine going up to fast on a trailer ramp, spring would stay on for one or two movements then pop, changed it out and no more issues.
Old 04-06-2018 | 04:52 AM
RANGER73's Avatar
RANGER73
Put a tie wrap on it or a cinch wire.
Old 05-01-2021 | 04:24 PM
markalvs@gmail.com's Avatar
markalvs@gmail.com
3rd Gear
Default Spring stud replacement
Did you replace the stud without removing the motor?
Old 05-01-2021 | 07:07 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Guess I'm pretty lucky, I still have my original spring and I clean the spring stud when I'm changing oil, I use brake cleaner, then use a spray on white grease. By the way, this is on a 02 Super Glide.
The following 2 users liked this post by seniorsuperglideE8:
markalvs@gmail.com (05-01-2021), Mongo7 (05-24-2021)
Quick Reply: Constantly throwing kickstand springs
