Suspension and tire Q
So i F'd something up on the bike. 1995 wideglide. I swapped my rear tire to a 140/90-16 commander II. My 11" progressive shock was popped and I was getting some weird feedback in corners and highway. They don't sell rebuilds for the 440. I threw on what i think are some SB stock 12.5" shocks (look like harley stockers and black) I picked up at a local shop. He said they'd fit and they looked good once bolted up. They also seemed to ride pretty smooth and highway wobble was much better.
Well a decent dip came up on me pretty quick and I bottomed them out. On impact my tail light was ripped off, the rear fender is pretty tweaked - enough to crack the paint in multiple spots. It looks like where the tail light wires enter the inside of the fender the impact severed them clean off at the hole. By the damage it looks like the rear wheel tried to come through the top of the rear fender.
Since I switched the tire and suspension at the same time I'm wondering which swap most likely caused this, if not both? The tire cleared my belt no problem so I thought I was okay.
I'll post a few pictures up in a bit. Nothing too horrible but I'm thinking I'll be needing a new fender either way.
He said it was off a newer dyna. He swapped to progressive for the customer and the guy said keep the shocks. They were black which is what made me assume Street Bob. They look brand new but I know that doesnt meant a lot. Not sure if anyone can tell by the look of them, but I'll get some pictures up here in a minute.
I didn't think about bump stop difference. I didn't notice rubbing on the sides like the tire was too wide or off center when I pulled over. It looked more like the tire was too tall or the suspension didn't completely bottom soon enough. Looks like a little over 1/4" difference at top of tire though, maybe that was just enough . Here are a few pictures not sure if they will help. Eye to eye unloaded these measure 12.5 .
Anyone near SoCal know of someone able to fix this and repaint? The tins creased pretty well in multiple spots. Looking at in more I'm not so sure the tire actually hit the fender, I think it sucked the tail light housing up under the fender which caused the damage.
I planed to find a pull off and repaint but I haven't been able to find one from this year. I see '99 but not sure if the rear is the same. Are sportsers from they year or newer similar width? I see those everywhere and wonder if it could be an alternative.
Rt13MFer (04-14-2018)
Received 5,703 Likes
I picked up some Joker Machine rear turn signals that I plan to wire in as Brake/Run/Turn signals. I bobbed this fender to remove most of the damaged area, pulled my strut covers and am just running it like that for now. After shocks I'll start trying to make it look good again, for now just gonna ride it.
At least its behind me and I don't need to look at it!
