Changed battery successfully but now bike won't start
Old 03-24-2018 | 10:47 AM
zbox2014's Avatar
zbox2014
Stage III
Default Changed battery successfully but now bike won't start
Hi,
I've searched the forums diligently so as not to repeat post but I can't find anything that helps. I recently replaced the battery on my 07 Dyna Superglide custom. The lights turn on, and electronics work fine, but now when I press the start switch, nothing. No clicking noise, no attempt to even turn over, just silence.
Is there something I need to do once I put in a new battery? Did I jar something loose when replacing the battery? Again the battery works and the motorcycle has power. Just nothing at all happens when I try and start up.
Thanks!!
Old 03-24-2018 | 11:54 AM
SC07Bobber's Avatar
SC07Bobber
Does the fuel pump kick on when you push switch to run. ?
Any recent mods beside battery?
Old 03-24-2018 | 11:58 AM
nevil's Avatar
nevil
Check your kill switch.
If you didn't unhook the battery cables in the right sequenced or hooked them up in the wrong sequence you might have blown a fuse by making accidental contact with the frame.
Old 03-24-2018 | 12:39 PM
beanoboy's Avatar
beanoboy
Are you sure that the battery is fully charged ? Do you have a voltmeter you can use to measure the volts ?...b.
Johnnyh14 (03-24-2018)
Old 03-24-2018 | 12:44 PM
cggorman's Avatar
cggorman
Do 07s have a dedicated starter cable and a separate main power cable? Are both connected?
Old 03-24-2018 | 12:45 PM
J F GO's Avatar
J F GO
Take it out and get it load tested. (Batteries Plus does it for free.) You may have good voltage but no amperage. Even new batteries can go dead.
Old 03-24-2018 | 07:28 PM
toddskill's Avatar
toddskill
I'm only a suggesting this because its not me before. Is it in neutral?
Old 03-25-2018 | 01:16 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Check you fuses and starter relay using this wiring diagram...
Old 03-26-2018 | 11:22 AM
zbox2014's Avatar
zbox2014
Stage III
Thanks everyone for the help. I finally have a day to look into it:
SC07Bobber - Fuel pump does kick on when switched to run. I wired a speaker to the battery and ignition switch successfully a couple of months before the battery had to be replaced. I tried hooking up the battery with and without the speaker wired and it made no difference.
Nevil - I will give the kill switch and fuses a look. A blown fuse may be it.
beanoboy - battery has been tested and is fully charged at around 12.6 volts.
cggorman - i'm not sure if they're separate cables to be honest. But it looks as if everything is connected
toddskill - It has been tried in neutral and in first gear with the clutch engaged
FXD2003Rider - Thanks for the diagram, I'm thinking it may be a fuse problem.
Thanks all!
Old 03-26-2018 | 02:14 PM
beanoboy's Avatar
beanoboy
Test the battery again by turning your key on for a couple of mins. [without starting the engine] then switch it off and test the volts at the terminals again. should not be lower than 12.6/7v...b.
Quick Reply: Changed battery successfully but now bike won't start
