Is a 2018 low rider as smooth as a 2017 low rider
Received 2,201 Likes
Received 5,746 Likes
The following 2 users liked this post by riderboy1961:
donmontalvo (03-10-2018),
Durham man (03-10-2018)
Same here! I wanted to cruise on an American Made bike. I had a choice. Harley Davidson or Indian. Victory was a no-go for me since they're no longer made. I tried both brands, several models. Eventually decided on a 2017 Street Bob. Part of the reason is the sound/vibration. It feels and sounds great!
I bought the same Upper Engine Mount that he uses and I also bought the Solid Aluminum (with No Rubber) handle riser Bushings. I was Pleasantly Surprised that the bike does seem to Handle Better AND has quite a bit More Vibration now, both of which I really like on a Harley.
The "Aftermarket" Upper Engine Mount keeps the engine from moving Side to Side but, still lets it vibrate frontwards and backwards, by doing this it helps keep the rear wheel In Line because our rear Swing Arm is Mounted to the Rear of the Transmission which is mounted to the engine, so if the Engine moves Side to Side much at all it will cause some rear wheel movement.
I have not looked into it but, if there were Solid Mount front and rear Engine Mounts for this model that I could install on my bike to replace the Stock Rubber Mount ones, I would.
I really liked the Vibration on my 96 Softail Custom, with the Rigid Mounted engine (engine mounted directly to frame). The faster I rode the more the vibration. I would have looked harder for one of those bikes but, I wanted the newer 6 speed with the Overdrive 6th gear for long rides out on the highways.
