2008 Fatbob Fuel pump issues
Old 02-23-2018 | 07:11 PM
case4777's Avatar
case4777
Stage I
Default 2008 Fatbob Fuel pump issues
My 2008 fatbob wouldn't start.
I replaced the battery, starter relay, checked all the fuses, and replaced the battery in the key fob. Nothing helped. I went ahead and replaced the fuel pump and filter and it worked! I ran the bike for 10 mins and turned it off. A week later I go to start it up and nothing. The fuel pump is not priming again. I check all the fuses again and everything looks ok. Any suggestions on what may be the problem?
Also, what is the best way to check for a short or a floating ground on the bike? Thanks in advance.
Old 02-24-2018 | 12:15 PM
nevil's Avatar
nevil
If there's a short a fuse will blow.
You should check the fuses with a continuity tester or DVM, a fuse can look OK but may not be when tested.
Try another relay, it's possible a new one can fail.
Check to see if you're getting power to the fuel pump. Check the kill switch.
Get the electrical shop manual.
Old 03-05-2018 | 02:50 PM
Nwminnesota's Avatar
Nwminnesota
I have a similar issue I am working on now.
Do you here your fuel pump turning on?
Mine currently I hear just the relays and no pump. Currently in the process of removing pump.
jlsmthrs97
11
06-12-2022 02:31 PM
gipper
12-01-2016 06:03 PM
Galderdrone
05-15-2014 05:55 PM
HarleyMast
12-06-2010 01:42 PM
live2ride777
03-09-2010 05:53 PM
Quick Reply: 2008 Fatbob Fuel pump issues
