I recently purchased in 2015 lowrider. The bars are not too offensive but I would like to change them. But from looking at them it appears the adjustable riser / visor headlight assembly would require reconfiguring depending on the bar choice? I. Think a set of lucky Dave's riser bars would provide the ride I want, with use of factory setup but I'm new to this so....here I am asking for feedback.
If you are looking to go to a traditional riser+bar setup, you'll have to ditch the factory adjustable setup. I did that, went to a bottom tree mounted headlight (you'll need a headlight bucket and block off a street bob or similar), bottom tree should already be drilled to accept a headlight block.
