Trans vent line removal?
Old 02-17-2018, 09:56 AM
Durham man's Avatar
Durham man
Durham man is offline
Received 1,651 Likes on 1,037 Posts
Default Trans vent line removal?
I need to replace rubber trans vent line. Can it be pulled out or do I need to remove top cover.
Old 02-17-2018, 10:07 AM
JohnMn's Avatar
JohnMn
JohnMn is offline
Just pull it off,, it's a common pipe nipple shape.
Old 02-17-2018, 10:08 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
You'll need to pull the cover to remove the vent line, it needs to be pushed in from the underside and the line has a squared off base that slides in to notches on the underside of the cover:
The following 2 users liked this post by TinCupChalice:
Durham man (02-17-2018), robertomendo (02-17-2018)
Old 02-18-2018, 11:17 AM
JohnMn's Avatar
JohnMn
JohnMn is offline
I'm an Idiot,
Old 02-19-2018, 02:22 AM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
I'm an Idiot,
The original poster has a later model bike, and it looks like Harley Davidson changed the design on the trans vent. The earlier bikes are just as you described, so no idiot award for you, sorry.
Old 02-19-2018, 04:38 AM
Frédéric CM's Avatar
Frédéric CM
Frédéric CM is offline
Looks like what TinCup said... at least for me...
Old 02-19-2018, 05:49 AM
TinCupChalice
I believe the change to the cover and vent hose started with the '09 model year. On pre-09 bikes the vent hose was a simple swap, once HD went to the #62372-09 vent hose the cover has to be removed to replace the hose...
Old 02-19-2018, 08:20 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Yeah...that hose nipple probably cost an extra fifty cents...and will never break, so...yeah...can't have that ****.
TinCupChalice (02-19-2018)
Old 10-12-2020, 08:40 PM
plymate zayleigh's Avatar
plymate zayleigh
plymate zayleigh is offline
Stage I
what is 18?
Old 10-14-2020, 12:25 PM
twincam10353's Avatar
twincam10353
twincam10353 is offline
Why do you need to replace it?
badknees
04-20-2023 04:06 PM
Agiuliano10
03-23-2014 12:54 AM
Fixedgame
General Topics/Tech Tips
03-06-2013 08:30 AM
xcfhxsfxblsx
Engine Mechanical Topics
11-18-2011 02:50 AM
Airborne350G
07-09-2007 03:07 PM
Quick Reply: Trans vent line removal?
