Oil leak from primary
Old 08-17-2023 | 07:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by Underwoodfarms
I have a 2005 super glide same exact issue. It sat for the year started riding it with the same fluid noticed a small drip of fluid on the bike building up at the drain plug. Thought it was the derby cover leaking for a while then to discover that it appears that it’s coming from behind the primary up by where the belt drive is
Ride it for a while before you tear into it.
Old 08-17-2023 | 01:33 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Using a flashlight and small mirror, check out the shift shaft going into the transmission from the linkage. This is an overlooked area and is a costly one when a shop repairs it. The gasket is inexpensive but the whole primary comes off to get to it.Sorry.
Old 08-19-2023 | 06:37 PM
seniorsuperglideE8
Should have looked at the date before posting, silly me.
underdog
33
10-25-2021 02:02 PM
Ultrascott
08-03-2012 04:40 AM
davefield
06-09-2012 05:07 PM
RICHE
EVO
10-10-2007 10:14 AM
missouri traveler
06-07-2007 05:01 PM
Quick Reply: Oil leak from primary
