Internal Handlebar Wiring
I realize this is pretty basic, but I just don't have any experience with it...
What's the deal with internal wiring?
I'm about to order a new set of bars, and would love to clean things up a bit... My assumption is that bars setup up for internal wiring have a hole under each control area for the wires to enter, and a hole between the risers for wiring to exit, and you cut your wires somewhere, feed them through the bars, and then splice them back together somewhere (with a disconnect for bar removal).
I don't think I'm misunderstanding anything, but if I am... Please tell me!
Next question: I realize this may be different with different bars, but is the hole under the controls usually located pretty exactly, or is there some ability for adjustment? I'm asking because I think I may want to cut 1/2" to 3/4" off each end of the bars I want, and I'm worried that may render the wiring holes useless. Or, I may want to rotate the bars further in one direction or the other... Am I wrong? Would it be easier to order bars with no holes, and then drill my own once I know exactly how they'll sit?
Thanks for any clarity, I've never run wires through my bars before...
Well you're right except for the part about cutting the wires. You de pin the connectors, run the wiring, and re pin the connector. Take pics first and watch YouTube so you know how to de pin.
No, don't go cutting the bars down. Order the ones you want or leave them, but I wouldn't cut em. The hole between the risers should allow you to rotate them forward or back.
F86 (01-09-2018)
Notice the elongated "dimples" and pierced holes at the switch housing locations. That's typical. They're pretty forgiving of switch positioning. The wire bundle sits in the dimple so the housing can clear and there's usually plenty of slop with the bundle inside the housing so they can rotate quite a bit.
You should be able to depin and fish the wires without cutting. There is a connector for each side stuffed down in the backbone.
F86 (01-09-2018)
Location: Depends on who wants to know.........and why.
Received 1,902 Likes
F86 (01-09-2018)
Since this came up, another option is to use weed whacker string, or you can use twine. I used twine twice and used a vacuum cleaner hose to run it through the bars.
Received 5,395 Likes
If you buy bars in a diameter greater then 1", they will have a step in them like the picture shown and will not allow you to shorten the bars. I drilled my own holes on a set of flat tracker bars from the MoCo after cutting about 3/4" off on each side. Worked just fine but they were a consistent dimension/diameter. Good luck.
F86 (01-10-2018)
Op- Might want to research that one before you spend the money as not all Dynas need extensions. I put 16s on my street Bob with no extensions. Same thing with my lrs, and my lrs had 5.5 inch drag bars stock. Unless you're goin with 19 inch apes, I think you'll be fine.
