fork oil
ORIGINAL: boogiewithtuck
2006 FXDBI 10,000 miles - had my fork seals replaced under warranty. I went w/ Screamin' Eagle oil and am very happy with the results. Much more stable in corners at speed. I did sacrifice a little comfort but it's very happy when I'm carving the hills.
lift the front, pull off the front wheel, pull off the caliper, pull out the tubes, put them in a table vise with a towel at say a 45deg angle, screw them out a 1/4 inch or so and then lean into it with your hand by your chest and start unscrewing slowly with your palm. it will pop off a little but you'll almost be embarrased at how afraid you were when it finally pops off. then, GREAT TRICK, measure how much oil you pour out, then you know how much to put back in (and not have to mess with the crazy instructions) assuming you haven't lost that much from a busted seal. probably need 4 quarts (bout 1 and 1/2 per), and reverse. pump the brakes to cycle the shocks a for a few minutes around the house and your off and running.
ORIGINAL: waterman7474
i totally agree. i just did mine this weekend and the difference is remarkable. and as for doing it youself, it is VERY EASY. i was way worried about the spring poppin off and crushing my forhead or something but it wasn't bad at all. do it with a buddy and it's easy.
ORIGINAL: vasser
Much too much work to remove the tubes when it can be done on the bike as long as the front end is raised off the floor.
I think you mean PINTS, not quarts of fork oil and I would refill with the recommended ounces vice measuring what came out because what came out may not have been the correct amount to begin with.
true....except how are you gonna get the oil out...06 and up doesn't have the drain.
true, i forgot the bottles were smaller. and i was probably incorrect in assuming that the factory would do it right, they have been known to screw up.
ORIGINAL: vasser
I think you were supposed to flip your bike over to drain the oil - I muss' a missed dat step in the manual too!
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
Received 4,571 Likes
