Camshafts 101
Camshafts 101
Can anyone give me a clear explanation and guide to upgrading cams? I see various listings for sale and see where it lists specs, but I'm not sure how they differ and their effects vs. stock configuration. For example, I'm running stage 1 - 103cu. in with exhaust, how would I know what else would need to be done to run right with Woods 555 cams? Learn me here please!
Ok this is gonna take a lot of reading on your part. I'm not very good at this so I'm gonna try my best. choose cams based on your particular riding style, aggressive, solo, highway, what rpm range you ride in the most, etc. keep in mind where you want your highest hp/tq. For me, the se259e on my 117 comes on around 3k-3500. You should also consider any future mods like big bore kits, headwork, compression ratio etc.
read as many reviews and threads as you can of people with similar mods. There's some helpful videos on YouTube as well. There should also be a few threads on here about can choice selection. It's not as complicated as it sounds, but the more you educate yourself, the better equipped you'll be to make a decision. It's also a good idea to look at dyno charts and compare them to your current setup.
Dont nt go too crazy with lift either unless you're doing headwork with it. Hopefully some of the more knowledgeable regulars will chime in on this one. Hope this helps
Are you asking about a guide to install them? Or are you asking which cams to get? There's youtube videos on upgrading cams. If youre asking which cam you should get, you need to figure out where you want the power and go with the ones that match your riding style. Typically the larger the cam, the more it moves the powerband to the top end/high RPM range. One thing I had to look at when I picked out cams was the maximum lift my valve springs could handle. I'm not sure what the max lift the springs on a 103 can handle but either pick a cam that doesn't exceed the max lift, or upgrade springs that can handle a bigger set of cams if that's what you want.
https://www.fuelmotousa.com/i-208596...camshafts.html
When you say the larger the cam, what are you referring to specs wise? I'll check out some YT vids too, and read my **** off. I'd like replace anything internal that is removed in the process with stronger components, just have zero idea what that is, obviously whatevers in the kits but still.
Moose545,
DO NOT OVERCAM!!
Do you want to go further than a cam only swap? If so, then you need to select the cam based on the engine modifications and the style of riding that you do. If to do not want to go into motor then pick a cam based on maximizing the stock compression. A Woods 555 is pushing it for stock. Look to a Woods 222 or an Andrews 48h first. Woods cams are pretty expensive for what they are. Not that they are bad cams at all, just better bang for the buck with Andrews
DO NOT OVERCAM!!
there is a good write up about cams in the engine mechanical forum section.
I did hours of reading and research before finally deciding on the woods 222, plus found a good price on a used set of them.
also if you do not have a tuner, that would be a good idea to pick up one when doing cams.
SarcastrophyIX (02-02-2018)
Thanks for the heads up, yes to cams and associated parts only, nothing more. I have the old orange SESTP but think V&H or FuelMoto would be a better and more user friendly experience probably. Meanwhile I'll pick a new stage1 air intake in the process prior and decide on the tuner then keep my eyes peeled for a used set possibly.
Can you explain the "too big/overcam" part for stock compression, using the numbers when shopping cams?
