PCIII questions
PCIII questions
I am getting ready to buy the Vance & Hines Bigshot Staggerd and go with a Ness Big sucker or a Screaming Ealge and the PCIII. The PCII site has a map that states it is for the following:
"Vance & Hines Big Shot Staggerd exhaust ,Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled"
So does it come with the O2 sensor eliminators? Will this void my warranty on my 07 WG?
RE: PCIII questions
Nawwwww.......My stealer installed mine and brought it up the day I bought the bike about the PCIII...
He claims it's the best and stands by Dyna....
BUT.....if you read in this forum about the horror stories people are having with it on 07 twin cams you might change your mind..
So far so good with mine but I haven't got my Bob wet yet....
[IMG]local://upfiles/23685/9895E1778C304BD7A4427E59D03EB334.jpg[/IMG]
RE: PCIII questions
If you order the PCIII for 2007 models, you will NOTget O2 eliminators. The PC III for 2007 models uses the O2 sensors. And says that a map like you mention will automatically be converted for use with the 2007 PCIII. What is harder to find out until you see the package and the one page manual, is that a huge area of the map is now off limits to changes by you. Well, it's street legal in California. That's how they did it.
You could order the PCIII for 2006 and get the O2 eliminators. But my dealer has said they've had problems getting the map right on their dyno for 2006 Dynas (the only 2006s with O2 sensors).
RE: PCIII questions
ORIGINAL: deeblues
RE: PCIII questions
The PCIIII bought stated it was for 07 models and it came with the O2 eliminators. They are mentioned in the map above because it is an option to use them or not. It runs great on my 07 Bob without any problems and the entire map range is available. For what it is worth, I did not use a Dynojet map. I used the map that was pre-loaded by Fuel Moto when I bought it there.
