Tank lift........Dented tank
RE: Tank lift........Dented tank
I just installed a 2" lift on my '07 wide glide today. Was getting ready to reinstall the seat when I thought I'd check for clearances. Top bolts on the tree hit both sides of the tank. Pulled the rear mounting bolt and enlarged the existing elongated mounting hole enough to get about an 1/8" clear of the interference end. Very happy with the looks and change in air flow around the tank.
If I hadn't checked the clearance I too would have had a dent or two.
ORIGINAL: Noride
I'm almost at the point where I don't want to do anything to my bike before I see it done. I know, so much for originality... but learning from own experiences can get expensive.
I take my time on upgrades of any kind due to this fact. Research is a pita but worth the time.
Is this probelm specific to the '07s? I have as 3" on my '06 FXDBI and my ridin' bud, Swoop_In, has the same on his '06 WG - no clearance issues, period. the only issue I have is the signal lamps can just touch my tank (but I have Night Train drags).
Just curious....
Just curious....
