Handelbars "creaking" ??
Kind of a strange problem I've got going on here... Last fall (or ****, might've been two falls ago) I had 10 inch apes installed on my super glide. Absolutely love them. But a few weeks back, I've started to notice some "creaking" going on as I apply pressure to them - either when pushing the bike forwards or backwards, turning, leaning into them, and most of all when I turn the fork all the way left or right til it bottoms out, and apply pressure. I especially notice this when the bike is off and I'm tryin to maneuver it around the garage. I get this creaking noise and this feeling like something is "loose." The problem is that I can't pinpoint exactly what it is or where it's coming from from the sound alone. I know that there's a naturally a wee bit of movement and give on the bars when you apply pressure, but I think I can say it's gotten worse.
My first thought is perhaps the bars are coming loose, which obviously is a bit of a safety issue.
But I had a buddy tell me there's no way those things are coming loose.
Has anyone experienced anything like this? If that description is too vague I'll try to post a video of it. Although I don't know that it will help as it's "felt" as much as it's heard. But it's definitely distinct.
I should also mention this hasn't happened since I've had the apes, only recently, maybe a month or so back. And it was progressive for sure, it didn't all happen at once.
Should I maybe try re-torquing the 4 bolts beneath the dummy lights?
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
well funny you mention those rubber mounts - It kinda almost sounds like THAT is exactly where the sound is coming from. Why do you mention those? And what would "poly bushes" do for me?
as you say...it seemed like a possible source of the creaking...also a good idea to firm up the mounts when fitting apes as the extra leverage of the taller bars exposes the weakness of the rubber ones...poly bushes take some of the play out of the setup and give better "feel" on tall bars
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Also - say I get the polyurethane ones... Is this a job I can do myself? I'm not stranger to wrenching, but if I have to start splicing wire harnesses, etc... ick. hah!
Man - I have to say I thought anyone that read this thread wouldn't be able to ascertain what the F I was talking about. The description of the problem I gave was pretty vague. If these bushings solve the issue, KUDOS on your troubleshooting abilities dude!! \m/
Thank you! This all makes a ton of sense. I'm going to start there I think. Can these rubber bushings be salvaged by tightening at all? I know you said just invest in the polyurethane ones, but I just don't wanna spend money if I don't have to
If you go poly, the Alloy Arts are around $40 on Amazon. Well worth it in my opinion.
Yes it is a straightforward install. Cover/Protect your tank and frontend. Unbolt the two riser bolts. Lay the bars back so you can access the stock bushings. Remove the stock bushings, and push in the new ones. Bolt the risers back on and you are done.
Thanks again for the tips everyone!!
