remove outer primary starter shaft busing
Have 95 FXDWG. The outer primary cover has a bushing pressed in for the starter shaft to extend into when engaging the starter. Mine is worn and needs replacement. What tool will ne needed to pull it? Would have to slide inside the bushing with arms/lip to grasp edge of bushing and a threaded base to pull it out. Anyone have a part number/description for that tool?
80Sturgis
Electrical/Lighting/Alarm
03-05-2010 10:04 PM
