2010 FXDWG rear turn signal problems
Old 10-23-2017 | 05:43 AM
mirrmu's Avatar
mirrmu
Default 2010 FXDWG rear turn signal problems
Hi
Have an international fxdwg 2010 so I have the centre break light with custom dynamic led clusters in turn signals
Right side flickers or doesn't work, when I fiddle with the AMP connector it will stay on until move wires around or try and feed back up into hole in fender
Do these AMP connectors go bad and do you have to change the femaie pin? Or whole connector
Thanks
Old 10-23-2017 | 05:58 AM
Mchad's Avatar
Mchad
Originally Posted by mirrmu
Hi
Thanks
The entire circuit board in the tail light base is replaceable. Believe those pins are soldered to the board. If your handy with electronics, maybe you could reflow the solder on the pins. Custom Dynamics sells complete boards for $25USD. Not sure what it is at the dealer.
Old 10-23-2017 | 09:30 AM
mirrmu's Avatar
mirrmu
The brake light works fine, the harness splits then to each turn signal with the AMP connector
YammyBase
04-18-2018 05:02 AM
homiegfunk53
08-01-2013 05:39 AM
Bullbutch
06-17-2013 03:23 PM
serge627
05-09-2012 05:57 AM
Eagle Flite
Electrical/Lighting/Alarm
08-17-2010 08:57 PM
Quick Reply: 2010 FXDWG rear turn signal problems
