Clutch issue
Sorry, but that's bassakwards.. making the cable longer means the handle has more cable to take up, hence closer to the grip... making it shorter means the clutch handle engages the clutch sooner- away from the grip.
You want your handle to be adjusted where there is approximately a dime's width between the handle and the handle mount, sitting static.
The adjustment changes the length of the housing not the cable ... the cable inside stays the same length.
2013_FLHTK
06-03-2017 03:59 PM
