straight pipes
Old 06-16-2007, 12:54 AM
fxsts1999's Avatar
fxsts1999
fxsts1999 is offline
Default RE: straight pipes
I have the Vance and Hines pipes thinking about cutting out the baffles and I guess get it dyno-ed. I heard these pipes running straight on a 2006 88" carb FXR and they sounded great.
Old 06-16-2007, 04:51 PM
cornishman's Avatar
cornishman
cornishman is offline
Night-Train01, a slight aside from the topic, but jeez thats one sweet ride of yours. Any chance of the background,I,m relatively new to the forum so sorry if this is a repeat question. Stay cool.
Old 06-16-2007, 07:09 PM
RAPTORAZ's Avatar
RAPTORAZ
RAPTORAZ is offline
I completely gutted the stock mufflers on my 07 Street Bob. I noticed no loss of low end torque. In fact it was a noticeable improvement in power all the way around. And it sounds hella better!
Old 06-16-2007, 07:13 PM
GeeRam's Avatar
GeeRam
GeeRam is offline
ORIGINAL: fxd2007
Has anyone heard that the 96" fuel inj. 07 bikesdon't work good withstraight pipes
Mine didn't
Had the straight-through V&H slip-ons on my FXDC and it popped and banged all over the place.....have just put in the quiet baffles so will see tomorrow if that makes any difference.
Old 06-16-2007, 07:24 PM
Trotter's Avatar
Trotter
Trotter is offline
Hope you drilled a 5/16" hole in the plug, Other wise If ya go to tune it ya cant get the rod up the pipe far enough. They will have to pull the baffles then drill the hole and try and reinstall them. Just a heads up... Vance & Hines should mention that in the Dir.. But they dont...
Old 06-16-2007, 07:28 PM
RAPTORAZ's Avatar
RAPTORAZ
RAPTORAZ is offline
ORIGINAL: GeeRam
ORIGINAL: fxd2007
Mine didn't
Mine rarely has any popping on decel. And when it does, its only slight.
Old 06-16-2007, 08:30 PM
99superglide's Avatar
99superglide
99superglide is offline
I've got two sets of slip-ons and can tell the difference mostly at about 4-4500 rpm's between them as far as power difference but it doesn't bother me much because I don'tpush it up beyond that.
I just drilled out the baffleplugs and put some thumbscrew type bolts about an 1 1/2" in from the end of each muffler. Sounds pretty good when you get on it butis quiet enough for cruising thru town also.
Old 06-16-2007, 09:55 PM
Night_Train01's Avatar
Night_Train01
Night_Train01 is offline
Cornishman, I bought a junk 1987 HD and then built my first HD project. It started out looking like this.....
[IMG]local://upfiles/6165/DC9166D0AC3143C3920E22AD4664FF31.jpg[/IMG]
Old 06-17-2007, 07:10 AM
GeeRam's Avatar
GeeRam
GeeRam is offline
ORIGINAL: Trotter
Nope, I didn't.........
But, it probably won't matter too much as I'm unlikely to be putting it on a dyno until after the warrenty expires......if at all.
apetterez
10-22-2014 10:28 PM
skinman13
09-10-2013 06:47 PM
Bumbobee
01-16-2009 08:30 PM
BIGDADI
06-01-2008 07:25 PM
codsack
03-30-2007 12:12 PM
Quick Reply: straight pipes
