Accessory power lost, fuses good, where to start looking?
I recently lost my accessory power, ignition on or accessory on I get nothing, checked my fuses and they are good. Bike runs fine and all lights work as needed, I just don't have any power to the accessory line. Where should I start looking.
I would start with the fuse contacts in the fuse box, look behind the box for a loose wire or broken tab. Then follow the wiring from there.
Unless you checked your fuses with a continuity light or DVM you might have a bad one that just looks good.
check connectors under the seat. Had a similar issue a while back and found the connector pin had corroded to the point where it wasn't conducting electrical jibbers anymore.
