For those of you running a quarter fairing...
Old 09-11-2017 | 02:36 PM
Northbound Southerner's Avatar
Default For those of you running a quarter fairing...
For those of y'all running a quarter fairing, what are you using to space the headlight? I put a Krator fairing on mine. Is super solid and a great buy for the money but I need the headlight up about 3/4" and out about the same for it it be perfect..
Old 09-11-2017 | 02:58 PM
CJD197's Avatar
CJD197
On mine the "bung King" brackets have enough adjustment to take the fore/aft spacing out. The strut releasess adjust the up down...but I set mine so I just run the upper quick-releases against the bottom of the tree. That way I can install in a minute without having to guess.
You may have to lengthen the adjustment slots if you are at the limit on your brackets.
Old 09-11-2017 | 03:44 PM
bigbadpoppa's Avatar
bigbadpoppa
Headwinds make an assortment of headlight mounts. You can try calling them if you need something more custom?
Old 09-11-2017 | 05:59 PM
STRES's Avatar
STRES
I used this for my gauntlet to have the headlight sit flush with the front of the fairing.
https://www.revzilla.com/motorcycle/...dyna-2006-2017
Old 09-12-2017 | 02:21 AM
Fireguy88's Avatar
Fireguy88
I use this with my JD Fairing. The pic below is what rifle includes with their roadster fairing.
http://jdcustomsandfabrications.bigc...-light-bracket
Old 09-12-2017 | 05:37 PM
REW13's Avatar
REW13
I have some brackets like the ones on the left and was thinking about using them for a tank lift??
those are about an inch?? right?
now as far as a headlight goes, what's to keep the light from slipping down?
Old 09-12-2017 | 06:27 PM
STRES's Avatar
STRES
There is a spacer in between the headlight bolt and you sandwich it together
Old 09-12-2017 | 09:35 PM
REW13's Avatar
REW13
I saw that, but wondered how it held up with the vibration.
Old 09-13-2017 | 09:16 AM
imboden's Avatar
imboden
I put on a krator last week. Found some spacers at my local ace. Had to turn around the original block, buy a longer bolt, and add a 1 inch spacer. Lines up perfect now.
Old 09-13-2017 | 11:03 AM
DivineDark's Avatar
DivineDark
I absolutely love your bike, man.
