Choppin the rear fender (pics)
Old 06-14-2007, 04:28 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Oldtimer of NM is offline
Default RE: Choppin the rear fender (pics)
If you are going to cut it to a different shape, be sure to put the bike up on a jack so it's level, or pull the fender clear off and work on it on a level bench. It's really hard to cut a fender straight when it's on a bike sitting on the sidestand.
If you are going to keep the same general shape, best to cut the forward edge, rotate the fender forward and redrill the mounting holes. This is how we did it in the days when rear fenders had a hinge to make tire changing easier.
Old 06-14-2007, 06:29 PM
rocklayer2's Avatar
rocklayer2
rocklayer2 is offline
Hey mud, I wasn't sure if I would like how the cut fender would look so I first came up with a patch for the brake light hole. I cut it out of aluminum diamond plate in hd's bar and sheild shape but I didn't like that So I welded the holes shut and welded and bondo the big hole shut. A little Rusteum flat black and it was done.
ORIGINAL: mudpuddle
ORIGINAL: rocklayer2
Here is a link to some more pics https://www.hdforums.com/m_1563884/tm.htm
I was lookin for that link rock.
So, did you cut yours yet??
mud
[/quote]
Old 06-15-2007, 09:00 AM
mud's Avatar
mud
mud is offline
muderator
Received 9,109 Likes on 2,119 Posts
Nice job on the slicked off tail Rock. That looks really good.
Keep up the good work.
Got a shot from farther back and off to the side??
Have you considered doing something with the turn signals??
I think they really distract from the clean flow ya got goin now.
mud
Old 06-16-2007, 07:24 PM
rocklayer2's Avatar
rocklayer2
Thanks Mud, glad you like it here are some other shots. Got any suggestions for the turn signals?
Old 06-16-2007, 10:22 PM
JimboFXD's Avatar
JimboFXD
JimboFXD is offline
used duct tape to mark the cut. Took two dremel cut off wheels. Laid an old towel over the tire incase I slipped. After you remove the stock plate mount you will see screw holes. I cut mine off even with the top hole.
[IMG]local://upfiles/5700/39881BFAFE9446A1A2855D6C81BE8A8C.jpg[/IMG]
Old 06-16-2007, 10:26 PM
JimboFXD's Avatar
JimboFXD
JimboFXD is offline
Rock layer I think your bike looks sick...If it was mine and the local law allowed it I would ditch the turn sigs.
Old 06-16-2007, 10:53 PM
rocklayer2's Avatar
rocklayer2
Thanks I'm glad you like it. It's forever changing. According to theAMA I don't need turn signals in PA. I would wan't to find that out for sure before I took them off.
ORIGINAL: JimboFXD
Old 06-17-2007, 12:14 AM
metal_mike's Avatar
metal_mike
metal_mike is offline
i just taped up the whole fender w/ blue painter's tape...marked my line...and used a cordless sabre saw to make the cut..then smoothed it out w/ a small file...since i cut mine so short,i also had to modify the 2 flat pieces[inside] that hold the fender on..when it was cut,the lil clips that held the signal wires tight to the fender stuck out like 2" so i cut them down and powdercoated them flat black so they blended in better...
[IMG]local://upfiles/19220/9542D37E596545D1A0A8159F643DD2D2.jpg[/IMG]
[IMG]local://upfiles/19220/F7B5A09DCECD421EB01BB7F5341D5146.jpg[/IMG]
Old 06-17-2007, 08:24 AM
mud's Avatar
mud
mud is offline
muderator
ORIGINAL: metal_mike
That looks really good mike.
mud
Old 06-17-2007, 11:55 AM
mud's Avatar
mud
mud is offline
muderator
Thanx for the pix rock. Looks good.
Like Jimbo says, you could shiitcan the signals and use hand signals.
I did for about the first fifteen years of ridin.
Don't remember when they started puttin em on.
It's a hassle but you do want other drivers to know what you're about to do.
Looks like mMike has the short standoffs. Doesn't look bad with the shorttailed fender.
I like some lighted indicators, so I used some small LEDs, pic below.
I also use hand signals if I see someone close behind.
Another reason I like some lights mounted, the coppers.
My policy hereis -
Never give a dog a reason to bark.
Alsopictured below are some small bullet indicator housings.
mud
Quick Reply: Choppin the rear fender (pics)
