rear wheel noise
Old 08-15-2017 | 08:16 PM
craigpell1's Avatar
craigpell1
Stage II
Default rear wheel noise
2013 Fat Bob, when going faster than 35mph with a rear passenger, the rear wheel makes a very loud whining noise whenever there is no load (accel or decel). Either engaging the clutch or coasting is when you hear the sound. It's quite loud and gets louder the longer the ride. Seems louder on the right side. Just had the rear bearings replaced a week ago, but the sound is still happening.
Old 08-15-2017 | 10:04 PM
archergodwin's Avatar
archergodwin
Check your belt tension and rear wheel alignment.
Old 08-15-2017 | 11:05 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Check to see if your brake rotor is rubbing on your caliper stay arm, like mine did.
wldbill (08-20-2017)
Old 08-16-2017 | 01:00 AM
Aussiemadness's Avatar
Aussiemadness
Sounds like tension or alignment.
Who did your bearings? trustworthy? could be installed incorrectly.
Dave.
Old 08-20-2017 | 09:44 AM
craigpell1's Avatar
craigpell1
Stage II
Default Thanks for the feedback!
The bearing was just installed by Great South HD (Newnan, GA) to combat this same issue.
I will check the other items mentioned, and thanks a lot for the guidance.
MCorso
07-01-2019 07:28 AM
BuddyK
Wheels/Tires
06-24-2015 11:19 AM
Rick Fowler
Wheels/Tires
04-28-2013 04:33 PM
sporty63
06-22-2012 09:45 AM
Springer97
06-03-2008 11:59 AM
Quick Reply: rear wheel noise
