New shocks!
New shocks!
After upgrading my forks to Ohlins NIX-22 (FKS-212) cartridges, I decided to get better shocks in the rear. The entry level S36e's are good, but after having the ability to fully adjust the fronts, I wanted that for the rears.
So I called Howard Messner and had him put together a set of 13.5" remote reservoir blackline Ohlins. They arrived today, so I naturally had to immediately install them.
I bought a cheap-o Ryobi 18v impact gun which makes life so much easier. Anyway, everything came off quick and easy, but it turns out I had to remove the e-series muffler. So that little pita notwithstanding, it took me about 30min for the whole job.
Actually remembered to measure the unladen length and set the sag once it was off the jack. Set the rebound and compression to the starting defaults per Howard's guidance and am ready for a ride.
I was initially expecting the added height to cause a lot of lean on the stand, but I'm not seeing it, so the money I wasted on a FXDX extended jiffy stand was exactly that, a waste... Oh well, to the classifieds I guess.
Unfortunately I had oral surgery this morning and the novacain is wearing so I'm going to treat myself to one of the Vicodins he prescribed me and relax. Probably not a good idea to ride, either in pain or on a narcotic.
I'll leave nice and early for work tomorrow and take the very long way there.
Anyway, here they are:
Vec (08-19-2017)
I just installed a set of 13.5" piggyback ODC shocks on the rear of mine yesterday. Did some testing and adjusting today. Holy hell, these things make a world of difference. It is night and day better than the stock "Premium" HD shocks. And th Premium shocks are good for factory!
Can't wait to get my adjustable +2" inverted front end next month to compliment the rear set up.
Hey Mchad I'm running the same 13.5" Blacklines as you on a 16 Bob, love Howard by the way, I would like some info about your E-series pipe from FuelMoto. I talked with FuelMoto and they said I may have clearance issues with bottom shock bolt hitting pipe. Since you put the longer shocks on what is your experience with the bottom shock bolt and pipe clearance?
Thanks, Joe
Thanks, Joe
Thanks, Joe
Thanks, Joe
Still need to break in, and I need a hell of a lot more riding to make a real judgement. Also need to do the zip-tie thing to measure total travel/preload. But so far, really happy.
Edit: My previous were the standard 12" length. These are 13.5
