Internal tooth cracking on rear belt
While removing the rear wheel for a tire replacement in noticed hairline cracks along the inner teeth of the rear belt. Admittedly, I been ignoring the belt noise (My bad, I know), but I've inspected the belt on several occasions on the cracks just now became noticeable. My trusty repair manual suggests that it's a problem with the front drive sprocket and that the both the belt and the sprocket needs to be replaced. The belt, obviously, but what about the front sprocket? Can anyone confirm this diagnosis before I start buying replacement parts? Thanks folks
belt/sprocket
I think running the belt too loose is the main cause for ruining the belt in the way you mention. It gets pretty pricey, so it's worth keeping the belt tension where it needs to be.
The manual says to change the front and rear sprockets when you replace the belt. I just went through it and it's a pain to change the front. Labor to do it is $$$$$.
The front sprocket is some type of steel and the rear is aluminum. I would change the rear out if it shows any sign of wear, but most likely you will be fine to just inspect the front sprocket.
The one on my 2013 still looked good at 110,000 miles, but I had already bought a new one and the tools to replace it, so I replaced it.
Tanker2
04-17-2009 03:04 PM
