Tire Puncture on a tubed tire - tire change?
Unless the nail is huge, you should be okay with a patched or new tube. I've done it many times.
Also, I run Slime in my tubes. I've done this for years and never had a flat tire. Lots of nails but no flats. The Slime sealed the punctures.
Such sealers also work in tubeless tires but create a mess at tire change time.
I would do Both while already in there, don't cost that much more to patch it as well replace the Tube ..
The primary purpose of a patch is to seal out air loss. A patch does not repair any possible structural damage caused by a nail that went through the tire carcass. Hence, there is no big advantage to patching the tire if a new or patched tube is used.
If it makes someone feel better, that's fine too.
I'd just change the tube. I'd highly suggest the wheel/tire plan from HD dealer. they give you a new tube, tire, and bands each time you get a nail. My old Fxdb was a nail magnet so I used this plan ALOT. Only downside is if it happens on a weekend, they can't get authorization til the next week.
Except that a patch my help to prevent objects from finding their way to the tube through the hole that is now in the tire......
