rear axle tightning
rear axle tightning
I just had new tires put on my 2012 fat bob and I'm reinstalling the rear wheel but I'm having an issue when I torque the axle nut. I'll get the wheel aligned and the belt tension set, then torque the axle nut and double check alignment and belt tension. The alignment moves after tightning. The nut side moves farther back. Has anyone else experienced this? Do I need to compensate for the movement? I have the service manual and have been following it. Thanks.
jaxwillfixit (12-30-2023)
Received 5,739 Likes
tar_snake (01-02-2024)
Location: Depends on who wants to know.........and why.
Received 1,902 Likes
Now - obviously ensure the bike is strapped down to the jack..., and the jack wheels locked - so it don't roll / come off the jack
Ghost
[QUOTE=Rubline;16434076]I would also readjust with the axle nut just loose enough so the wheel can be adjusted. You don't need to loosen the nut that much at all to adjust.[/QUOTE
I think thats what was causing the movement. I was loosening the axle nut to much. When I would snug it up you could see the swing arm pull in a tiny bit and then I would check alignment again and it had moved . I started checking with the nut tight and was able to get it where I want it. Wish they had a better way to check alignment and belt tension. Thanks for the help.
I tap the allen heads on the adjusters as I tighten with a mallet. Check that the bolt head hasn't moved and if it has I restart. I always double check the alignment afterwards. Someone makes some handy axle plugs for this purpose that are about $100 cheaper than the Jim's ones that you can find on eBay, don't even know how much Harley's version costs. They made the process easier for me because it's easier than trying to reapply tape to try to get the center of a hollow axle.
