New front predator and OEM rear motor mount, Problem.
Old 06-28-2017 | 11:38 AM
wideglideCVO's Avatar
wideglideCVO
Default New front predator and OEM rear motor mount, Problem.
I put a predator motor mount on the front of my wide glide and changed the rear OEM mount also. The old rear one was in great shape. Bike ran good for a few weeks no problems. All of a sudden I feel a vibration and thumping noise on my front pegs, feels like it is also under my seat. I loosened all the bolts on the predator and ran it for 10 seconds and re-torqued bolts. Same issue. Feels like the back motor mount I put in is having an issue? Any advise would be appreciated.
Old 06-28-2017 | 12:01 PM
Jay Guild's Avatar
Jay Guild
I would try re-balancing the top mount with the new lower mounts. Things may have shifted.
Old 06-28-2017 | 12:05 PM
wideglideCVO
Should I loosen the front, rear and top stabilizer and run the engine for 10 seconds or so?
Old 06-28-2017 | 02:21 PM
Smogbob's Avatar
Smogbob
Might not be the motor mounts, could be a bearing is giving in somewhere, possibly rear wheel.
Old 06-28-2017 | 04:09 PM
wideglideCVO
Thanks I will check them.
Old 06-29-2017 | 10:16 AM
Jay Guild's Avatar
Jay Guild
Follow the manual procedure for aligning the top mount.
wideglideCVO (06-29-2017)
Old 07-03-2017 | 06:27 PM
Crazy's Avatar
Crazy
Did you ever get this problem solved?
Old 07-10-2017 | 01:50 PM
wideglideCVO
Yes, it was 1 1/2" fork stem nut. the lock washer spun a little loosened the nut. Then tightened the adjuster nut a little, tightened the stem nut back with a new lock washer no more clunk or vibrations.
The following 3 users liked this post by wideglideCVO:
Crazy (07-10-2017), Protocol (07-11-2017), Smogbob (07-10-2017)
Old 07-11-2017 | 09:10 AM
Protocol's Avatar
Protocol
I have a similar noise/thudding under my seat that I have been unable to resolve. Sounds like the same symptoms. I will be checking this out tonight. Thank you!
Old 07-11-2017 | 10:14 AM
Smogbob's Avatar
Smogbob
Check your tank bolts are torqued to spec also, sometimes they come loose, and also exhaust brackets and bolts.
Protocol (07-12-2017)
Quick Reply: New front predator and OEM rear motor mount, Problem.
