throttle choke
throttle choke
Why does my motor stall or choke out when I twist my throttle quickly. I have to ease into first 1/8 or 1/4 turn, or my engine wants to die out. even if i push throttle lever at carb, same same.If I push it quickly, as if I blipped the throttle back quickly to get a quick rev, the motor chokes out, but doesnt die.
First of all, you don't have a carb.
Not enough info-
Any mods on the bike, like a tuner, etc?
How many miles? You could have a hole in the internal fuel line or a clogged filter. Dirty IAC is possible, too.
What do the plugs look like?
When was the air filter last serviced? It could be dirty.
Not enough info-
Sounds like an issue with your tune. I'm not at all familiar with the FP tuner so I couldn't say what to adjust. I have had similar issues in the past and was able to cure it by raising the "accel fuel" (thundermax tuner) which is like adding a bigger pump jet on a carb.
the bigger question would be did this just start happening? Had it always done this? Was it after installing a mod? You might also check for exhaust leaks as i've seen that cause this issue aswell (rev match on down shift, throttle blip would cough).
