rigid chrome sideplates
RE: rigid chrome sideplates
The instructions are so simple, you don't really need them,theyfasten at turn signal and fender mount. They should be positioned right against fender, behind that black bar, no extra fasteners are needed, the ones there will suffice.Shiney side out with the channel for sissy bar positioned inward. I had to loosen the shocks slightly to get them in position.
The job is a lot easier if you slot out the rear bolt hole on the mount so all you have to do is loosen the rear bolt and drop the mount in place instead of removingthe boltcompletely.
Good Luck
Tom
[IMG]local://upfiles/8936/012198D556424F9D83FB9056E5C6DD4D.jpg[/IMG]
Good Luck
Tom
