3" risers for low rider S
On mine, 2016 LRS. Two inch risers worked just fine. However, the clutch cable needed a bit of rerouting and is working great. My front brake line could not be rerouted and works fine but has no additional length. Possibly the full three inches would be to much for the brake line. All of the other wiring is plenty long with additional length tucked away.
Just installed the DK 3" risers on the LRS. j0ney3 you're right; they fit - barely. I needed the extra height, as I just installed a LePera Dayton daddy long legs seat, which pushed me back away from the bars. Got the leg room I needed, but it changed my reach. The 3" risers are just what I needed. DK guys are great BTW.
3" risers for LRS & other mods
DK 3" risers; DK 2" tank lift. Road yesterday after the 2" tank lift install, and my head temperatures (HT) were reading 260 -275. The day before (same weather conditions) without the tank lift head temps were around 300. I'll continue to nerd about the HT, and might consider the LJ mighty mites if HT rise to 300 during the hotter temps in summer. Anyone else monitoring HT with the 117?
The following 2 users liked this post by buboje:
Craigmier (07-01-2017),
TOE_CUTTER (02-18-2018)
