Metal shavings in primary
#41
I wouldn't jump to any conclusions just yet. It might be a simple fix. There isn't anything wrong with the compensator you're running. Baker has had issues too with theirs. Take your time, see what you see. Warranty's are good for simple stuff but the more complicated you'll be better off figuring it out yourself. At least you're in the position to do so. And with the family connection to both dealerships it really isn't worth fighting this one over what might end up costing you $150 in parts for a new clutch hub (if that's what it is).
If it were up to me buying a new bike I'd rather have $1k back and a limited warranty.
i dunno, this problem started with the 110, now that I have the 117, I'm sort of reluctant to put oe parts back in it. I was listening with a stethoscope at work yesterday and I couldn't hear the bearing over the primary chain noise (wondering if the auto tensioner is too tight, maybe where this all started) but I could hear the knocking loud and clear by the compensator. Either way I won't know anything until I tear it down and see it with my own eyes. Assuming the compensator is bad I'd much rather upgrade it but I can't find any for my bike.
#43
#44
#46
Did you ever find out what the issue was? I was performing my 20k mile service today (2014 stage 1 Street bob) and found similar chips when I pulled the primary drain plug. I have not experienced any odd noises or behavior from the bike though. For now I plan on just refilling the primary and bolting it back up and checking back in on it in 1,000 or so miles.
#47
