Strange sound
It can't hurt to double check the tank bolts. Also the heat shields.
A bad motor mount should be obvious, but if you can't see that the rubber is trashed, get a pry bar between the frame and motor and see if there's a lot of movement.
Torque specs are in the shop manual, but here are some:
http://www.nightrider.com/biketech/hdtorquevalues.htm
Proline1969 (05-20-2017)
Ok , I've got the bike in the air . Checked for freeplay in the steer stem seems fine but wouldn't hurt to replace since the bike is 8+ yrs old ( 3200 miles ) . More concerned about the age and not the miles . Torque on motor mount is fine also , I noticed the shifter seems to be very loose side to side . Is this normal ?
