MoonsMC LED for Fat Bob?
Received 2,201 Likes
read... not expressly mentioned but, was mentioned
https://www.hdforums.com/forum/dyna-...for-250-a.html
I have one on my Lowrider, and I love it. It makes the stock headlight look like a kitchen match. Plus, I'm sure the reliability factor is going to be a couple of orders of magnitude above the $45-$90 Amazon knockoffs.
I have the fat bob ones, I like them enough but don't have anything to compare them to other than the crap 7 year old stock halogens that I had before. My only gripe was that the adapter seemed pretty poorly made with the pins too long, and the bucket doesn't have a ton of extra space to begin with. It will all fit, but I decided to do some soldering to eliminate some of the bulk in the headlight bucket. Here is an example that shows the long pin problem:
https://www.hdforums.com/forum/dyna-...installed.html
And here are some pictures I took with the moons headlights installed to give you an idea of light output:
https://www.hdforums.com/forum/dyna-...eadlights.html
Hope this helps you.
Velocity Ray
07-02-2019 03:24 PM
