Low rider ground clearance
Old 05-13-2017 | 04:04 AM
tscad's Avatar
tscad
Stage I
Default Low rider ground clearance
Hey everyone, greetings from New Hampshire.
I'm looking to trade in my 2016 XL1200C for a low rider or a street Bob. Love the comfort of the low rider but it seems to have a bit less ground clearance than the bob. Can anyone compare the ground clearance of a sporty to the low rider and street Bob? I like to push my bikes in the corners and I'm wondering if the low rider is capable of leaning a healthy amount.
I have tested both the low rider and Bob but did not get too aggressive with them.
Thanks for any input!
Old 05-13-2017 | 05:45 AM
JayStronghawk's Avatar
JayStronghawk
Depends on the Sportster you Have .. Some of them Have Very Little Ground Clearance, Some have Plenty Depending on the Set up and Shock Length .. My FXD Super Glide is lacking a bit of Ground Clearance but can live with it .. When Test Rode the Low Rider Not sure what the suspension is, but scraped it a lot almost every decent turn .. Scraped the Sportster Shown Once in a Tight Switchback ..
Old 05-13-2017 | 05:54 AM
Chiggerbutt's Avatar
Chiggerbutt
You can go to the harley website and compare them side by side. That has always been helpful to me when shopping around.
I also know the value of asking people with experience, of which I don't have on the bob, so good luck in your search.
I also love riding my LR, but I'm coming from the touring side of things (which I also love).
Last edited by Chiggerbutt; 05-13-2017 at 05:58 AM. Reason: forgot to add something
Old 05-13-2017 | 12:01 PM
Highwaymans's Avatar
Highwaymans
If you like to push it in the corners, youre gonna want to put real legs on it anyways. Get the one you like and upgrade from there. Youll be happier in the end. Doubt theres alot of clearance between the two stock to make that the deciding factor.
Old 05-14-2017 | 12:45 AM
archergodwin's Avatar
archergodwin
Old 05-14-2017 | 06:17 AM
petefwa's Avatar
petefwa
That's the first thing l noticed when l switched from a Sporty to a Dyna about 10 years ago, it's something you learn to live with and fitting 1'' longer rear shocks makes a big difference.
Old 05-14-2017 | 06:32 AM
JayStronghawk
Thumbs up
[QUOTE=petefwa;16234879]That's the first thing l noticed when l switched from a Sporty to a Dyna about 10 years ago, it's something you learn to live with and fitting 1'' longer rear shocks makes a big difference.[/QUOTE]
Very True , The Difference in 5" and 6" Ground Clearance means a whole lot more Lean Angle can get away with ..
Old 05-14-2017 | 08:28 AM
kontiki's Avatar
kontiki
I used to have a XL1200L. I would scrape the jiffy stand mount all the time with that thing on left turns and pegs and pipes on the right. The FXDL can lean much better. It will occasionally rub a foot peg but not often.
Old 05-14-2017 | 02:06 PM
NorthWestern's Avatar
NorthWestern
Just get the LRS, and you will get your shocks.
Old 05-14-2017 | 05:10 PM
petefwa's Avatar
petefwa
l've got Emulsion shocks on my 014 Lowrider, they're a fair improvement over stock but they don't actually increase the ride height.
